Forum - Golf 2 (83-91) - GT Special - Vad är special?
m_ors
Golf 7 1.4 -17 Ort: Malmö
Mån 14 maj 2007 14:28 Svara med citat
Ja, jag har köpt mig en MK2 GT Special. Det roliga är att jag har ingen aning om vad "Special" innebär. Har googlat runt lite och hittade bara "A Golf "GT" model was also briefly available in North America." på wikipedia.
Så, någon som vet?! Very Happy
Mån 14 maj 2007 15:51 Svara med citat
Har inte den blekaste. Men ett hett tips kan ju vara http://www.faltdach.net/index.htm eller gtiklubbens broschyrarkiv.
står mycket där Regular Smiley
Tis 15 maj 2007 0:14 Svara med citat
har förmodligen lite med plast- & interiör detaljer att göra.. dvs inget med motor & låda..
SvartaGolfen
Golf 2 1.8 CL -90 Ort: Orsa
Fre 18 maj 2007 15:11 Svara med citat
Hittade detta på nätet,men det där med special måste jag leta vidare på:
Q: What does GTI, GLI and so on mean?
A: L = Luxe (base model)
LS = Luxe Special, couple more do-dads
GT = Grand Tourisme, better equipped & usually a larger engine than
the "L" series
GL = Grand Luxe (geared for more luxury), basically == GT
GTI/GLI = Originally, the fuel injected version of a GT/GL which means it
produced a lot more power. With most cars FI, the GTI/GLI
designation means a more powerful engine than a GT/GL model,
sometimes also with a better suspension. Note that originally,
GLI != Jetta, as the case in the USA.
SL = Serie Limite' (limited series), like the Karmann series in US.
Really a variation on a GT.
GTX = Same as GTI but used in Europe and elsewhere.
G40/60 = GT version with VWs G-type supercharger. The number is the width
of the G-charger (lader in D) coil in millimeters. For those who
aren't aware, the G40 is used on some Polos, the G60 on Passats
and Corrados.
VR6 = Cars based on the new staggered 6 cylinder engine (in-line-V-6).
SLC = Sport Luxury Coupe, the VR6 equipped Corrado in the US.
Syncro = VWs version 4WD distributes its torque with a "visco-gear"
(It's a special silicone gel that stiffens if the relative
motion (shear) increases)
VWs 4WD is designed by Steyr-Puch, an Austrian Company and not
by Audi.
m_ors
Sön 27 jun 2010 13:30 Svara med citat
Tre år senare kan jag avslöja att jag fick svaret för ca tre år sedan. Smile
GT Special = Allt i GTI-väg, förutom motorn. I mitt fall var det farthållare, skärmbreddare, "sportstolarna", fabrikssänkning o.s.v.
P.Hagel
Golf 1 GTI-83 Ort: Växjö
Sön 27 jun 2010 14:30 Svara med citat
FEL !!!!!
Gti special på 1988 och 1988B var/är en 8v gti på 107hk.
m_ors
Sön 27 jun 2010 15:29 Svara med citat
Fel?
GT Special, inte GTI.
ROSSAN
Donator 50 Golf 3 vr6 Ort: Stockholm
Sön 27 jun 2010 16:31 Svara med citat
Här har du ju annars alla modeller och specar på utrustning osv
http://www.doppel-wobber.de/wbb2/VW-Golf-2_Modelle.html
Det är inte farten som dödar, det är smällen. Eller...
m_ors
Sön 27 jun 2010 17:08 Svara med citat
Yes, här är då den jag hade
http://www.doppel-wobber.de/wbb2/Modell_42_VW-Golf-Special.html
Wink
P.Hagel
Sön 27 jun 2010 20:37 Svara med citat
Wink
Ursäkta......
m_ors
Sön 27 jun 2010 21:08 Svara med citat
P.Hagel skrev:
Ursäkta......
Inget att be om ursäkt för. Smile
