Forum - Golf 7 (13-19) - BMS
creasy
Golf 7 Ort: Norrköping
Lör 11 feb 2017 23:54 Svara med citat
Finns det här i golf 7 BMS (Battery Monitor ?
Hunter
Golf 7 S-combi 150 tdi 4-M Ort: Örebro
Sön 12 feb 2017 2:22 Svara med citat
Det finns denna i Golf 7.
Display the battery charge level or SOC (state of Charge)
Enter [17] Instruments
Go to adaptation channels, (no need for a security log in with this module)
Scroll down until you see Battery Charge > simply change it in the new value drop down to "active" and it's done.
Usage
Switch the ignition off, then press (and continue to hold) the trip reset button in the middle lower of the instrument panel. It will cycle from first resetting the trip to 0 miles > show "Time" to allow you to change the clock > then keep holding until say "Battery".
Release the button and display SOC for a few seconds before returning back to the main screen.
I min bil var det redan aktiverat när jag köpte den men den hade gått ca 2000 mil vid inköp så vet ej om förra ägaren hade gjort det eller om vissa bilar har det redan från start?.
Kopierat från:
http://www.golfmk7.com/forums/showthread.php?t=2491
VW GOLF VII SC 2,0 TDI 150 4M GT 2014.
VCDS.
